Above the Clouds for Iray: Nimbostratus-Problem Rendering-Solved
SiennaBlueSiennaBlue Posts: 224
edited March 2017 in The Commons
Hi.  I'm just testing out this cloud product by Marshian and I'm getting a weird artifact.  It looks like the outer "rim" of the cloud prop is lit up.  I can't figure out what I'm doing wrong.  Has anyone else experienced this issue when using this product?  Thank you!
Post edited by SiennaBlue on
  • SiennaBlueSiennaBlue Posts: 224
    Just updating this in case anyone actually wonders about this.  That is the seam for the prop.  I wanted to overlap several small cloud props with different densities, but, apparently, I need to use just one large prop and position it so the seam is not in the camera view.  This is a great product, though.  I just made a mistake using it properly.
