Lighting with HDRI: How do I change the sun's position?
colinmac2
Trying to get a more natural look with "Sun-Sky Only" lighting in render, but the sun's in the wrong place to illuminate the model properly. Can this be changed?
Yes, you can set an item (most usually a camera) as the Sun Node in Render Settings and then use that to set the direction of the sun.
