Adding to Cart…
wow kittingmommy that looks awesome, I bet the wings properly added to your render time too
Thanks. As to the render times, very possibly. I'll need to render the wings by themselves and the skydome by itself on my setup and see what my render times are with the separate products. I really do like how he turned out and that skydome was perfect for how I wanted it to look. :)
Thank you firewarden :)
Purchased this item, everything as advertised and then some.
Coincidentally have another of your products Epic Props: Godrays & Volumetric Light for Iray.
Was wondering about advantages/disadvantages. problem with combining both in same scene
Your thoughts?
Thank you
Oops, my fault here. I should have had the FF filter on by default... will have to update.
Nice work by the way. The third image reminds of the movie Oblivion.
Nice work Knittingmommy...very creative use, and nice atosmphere.
bicc39,
Yes you can certainly use the Godrays in the skydome as well. I didn't really test it though, so I don't know how far you can take it.
Thanks! :) Already thinking of what else to set up with the skydome.
Thank you!
Thank you!
I note that you also set the Max Samples down to 100 (from the default 5000) - my first couple of renders seemed to finish in a blink of the eye, but were very speckly until I raised the number. Is the 100 also an error or just optimistic?
ETA: Just to add that I do love the product and am very pleased I picked it up. Here's a first look from me (increased samples but FF filter not set "on" as I hadn't noticed until I read the post above!)
Posted with permission. :)
All Squirrels go to Heaven
I really love these skydome!! :)
Oh, my gosh! Too much cuteness!
All of the pix in this thread should have been promos!!! I would never have hesitated. I just hope it goes back to the MM discount soon.
@firewarden - Thank you. :)
Good render settings here: http://www.daz3d.com/idg-easy-iray-studio
I grabbed the Goliath MST in the vehicle sale - and ended up with this:
A quick use from me:
@Knittingmommy
Another setting you can try is Render Settings>Optimization > Max Path Length and set to something between 8 and 11. The default allows and "infinite" number of light bounces.
(PA_ThePhilosopher: "I am guessing that the fireflies are due to the volumetric cube, since light bounces around inside it for an eternity it seems ")
Hey thanks for that tip .. that worked great
OMG how cute. lol
Thanks Ivy :)
I'll try that when I render it again. Thanks!
Agreed! Awesome!
@Ivy, @ Knittingmommy : "Thanks!"
My pleasure. Happy to help.
Love your products... Please do a whole series of kick-ass skydomes!
Hi PA_ThePhilosopher . please keep making these great skydomes. If I can I would like to make a sugestion for one if I may . I think a Stormy skys skydome would be awesome. . anyway this is my latest render using the epic skydome, that I paired with the epic lensflare , great results "Really a great HDRi skydome, " the stormy skys would be awesome to pair the iREAL water system hint hint..lol :)
Heavens Gate
I've done two images using this product, and I'd like to think they came out okay. However, I cannot for the life of me get the shadows to show up reliably in the light cube provided, even with a fresh 'default' scene. I've read the readme, and it doesn't answer my questions. (And no, the light cube object is not in the following images.)
1. Does the object itself have to be fully encased within the lightcube for the shadows to function?
2. Does the lighting have to be uber bright to get the shadows to show up?
3. Even at the lowest settings, I noticed that the light cube had distinct edges to it, even when at 45x45 degrees.
Is there a reason there are 5 HDR files and 1 PNG file? Why not all HDRs? From my understanding an HDR stores more levels of brightness and should be the preferred file, unless there's some reason I don't understand for having one of them as a PNG. Also, why when I load all 5 HDRs, as skydome only, does it change my render iterations to 100? (Loading the PNG one doesn't do this at least.) I find that rather annoying. When I load an HDR I don't want my render settings changed. I can understand if I load the scene files, but loading an HDR should leave my render settings as I have them.
