Accidentally hid items in Advanced Tab - how do I show them again?
I'd like to ask, how do I show all my items (figures, clothing, props, etc.) in my Advanced tab again? Reason I ask is because I accidentally hid them when trying to perform a task.
I meant to say, I may have hidden all my items in my content library. I am not sure if I accidentally deleted them in DAZ Studio, but how do I get the items to show again?
In which list? DAZ Studio (or Poser, or Import) Formats, Categories, or Products?
Everything in the Content Library tab. My Library, My DAZ 3D Library, everything.
Though if I do use the search engine, it can retrieve the item no problem. But the library won't show. What do I do in order to show the library items again?
Do you suppose I may have accidentally deleted my mapped directory? If so, how do I get it back?
Better yet, how do I restore the directory to my content library? I tried to find Add Directory, but what path would I have to take in order to access the Add Directory?
Do you mean the folder list is not there? That probably means you have collapsed it - if you have the list at the side usually there will be a dark mark half-way down the left hand edge, if at the top there will be two dark marks stacked above the number of items showing text at the top of the empty file list - click the dark rectangle on the left/the lower dark rectangle at tht etop to reopen the folder list.
When you say the dark rectangle, do you mean the minus sign? The buttons on the left, I believe, are accidentally disabled.
How do I enable them?
The images show the button I mean in both collapsed and open state, with the folder list (in tree view) at the top of the pane.
Okay, I am on the right track. But now I am showing check boxes for each library folder. How do I make them actual folders again?
Those are the search filters - the top button of the double stack if the folder list is on top of the pane. Since you have only one I think your collapsed folder list is on the side (the button is actually half-way down, I cropped the image).
