Fox without Fur?
Forgive my stupidity here - but I just bought Red Fox by AM on the strength of the promo images. No mention made of additional products required - but I am assuming that when I load my LAMH Fox figure & render - it has no fur because I don't have 'Look At My Fur' installed. I can easily buy the LAMH product but money is tight right now so only if it's necessary. So I just need confirmation that this additional product is absolutely needed - also, could someone drop a line to AM & suggest they might add 'required product' to their product page? For the new & niave of us out here it helps to know this stuff upfront.
http://www.daz3d.com/red-fox-by-am
  • scorpioscorpio Posts: 8,533
    The fur won't show up when you render in Iray unless you explort as an obj, it will render if you use 3delight to render.
  • RixstudioRixstudio Posts: 37
    Thank you both - have installed the LAMH reader. Real good to know about Iray render issues too - that would have kept me quessing (& cursing) for eons. Thank goodness for forums & the collective knowledge of the Hive Mind!!
    Anyone reading this & facing similar difficulties with fur - I just found this tutorial from AM - very helpful.
