Need help importing FBX into cinema 4D with animated facial expressions
Hi everybody,
So far I've been able to export an FBX file from Daz studio pro 4 with animations and import that file into Cinama 4D R13. So far with some tweaking to the materials, everything is looking good and animating fine, with one notable exception:
No animated facial expressions.
Is this a bug or is there some setting that I'm missing in the export settings for Daz or import settings in cinema, or both?
Thanks in advance.
- Rex
can you tell me what your export setting are in Daz and your import settings in C4D?
I am also having this exact issue. The animation keyframes come across but none of the morph animations.
I am exporting as FBX, with head.CTRL morphs rule set to export. It opens fine in Cinema, I can modify the morphs, but they aren't animating. Has anyone gotten this to work? Any ideas of what I could try? Thanks!
