Preferences not available
frodifrodi Posts: 0
I reinstalled DS and also Genesis Starter, now I cannot get into preferences to tell DS where to look for files. I open preferences and only get this:
  • frank0314frank0314 Posts: 14,765
    Right click on the content library tab and select Content Directory Manager
  • frodifrodi Posts: 0
    It does not respond to a rightclick, the tab that used to be at the top-end, where you could click to get to preferences has also disappeared.
    Which layout are you using
  • adamr001adamr001 Posts: 1,322
    There's a context menu icon at the top of the Content Library tab. Left click that (not Right) and you should be able to bring up the Content Directory manager.
    513 x 440 - 28K
    Thanks for that! I changed to to city-limits and now I can get to the preferences. However, although I have set it to DS and Poser Formats, only the DS stuff shows up as selectable.
    497 x 470 - 40K
  • Richard HaseltineRichard Haseltine Posts: 109,263
    What do you mean when you write "only the DS stuff shows up as selectable"?
    When you click on Poser Formats a small dotted line box should appear around it. Once you do that the Add button will light up and you can add a new Poser Format directory. You should have a similar box when you click a member of the Poser Formats list but the buttons Edit and Remove will be lit instead.
    442 x 362 - 26K
    506 x 369 - 20K
    Thanks Adam, I have put a corrected path to the Poser directory, and now it all works again. You always give excellent advice.
