What clothes does Elijah 7 wear?
danygol
in The Commons
Can someone point out what props does Elijah 7 wears on those 2 images?
Well that first one is the Renegade pants with a custom transmap to make them cutoffs, and the second are the pants from the Nomad outfit.
I swa the resemblance, but I did not find this Add-On anywhere. I see there is not only transmap but also a texture.
Are this transmap and textures available anywhere?
I honestly don't know. It was probably something that was made by whoever it was who did that promo image. It could be duplicated, by taking the pants image texture into a photo editing software, converting it to a black and white image then erasing the part of the pant legs you don't want to show, then saving the image and putting that into the Cutout Opacity channel in DAZ. It would require a bit of effort but it's doable. Just remember for transmaps: White is visible, Black is invisible.
And as for the color of the pants, the promo artist probably just darkened the color of the Diffuse Channel in DAZ to make the pants look darker.
Custom trans maps are really easy to do. You just need a black and white image put into the opacity map. Black is transparent and white is opaque. In other words, black for the part you don't want to show or want to be invisible and white for the parts you do want to show. You'll need a copy of the UV map or a template if there is one so you can line things up. I have a tutorial of sorts on my lab thread for a different outfit but it will give you some idea of what you need to do if you've never done it before.
Here is a link to an outfit where I cut off part of the top and gave it a somewhat ragged edge. I hope it helps.
