Help needed with transferring/restoring/Installing Daz Studio 4.9+
Turk_WLF
I just got a New Computer (Windows 10) but I need help setting up Daz’s DIM & Installing Daz Studio 4.9+ plus Hexagon 2.5 and Carrara 8.5 Pro.
The Problem I’m having is that DIM wants to install everything on my C: Drive which the smaller of the 2 Hard Drives. I want to install all of my 3D Programs (if I can) on my Larger Drive.
I’m not sure how to reroute the folders where I want them to go. If I could do a simple drag & drop I would have it installed by now.
Thanks,
In Install Manager click the gear icon at top-right to open preferences. Ypu can set the download location in the Downloads tab and the paths to isntall to in the Installation tab. Make sure you update the content dierctory settings in DS to match - Rob does have a sample script to help, or to set DIM's install paths to match the DS content directories if those are already done:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config/start
