Looking for kitchen with hideable ceiling and walls
I'm seeking a kitchen whose walls and ceiling are hideable for iray. The last two I own do not have a ceiling I can conceal and my efforts with geometry editor haven't worked, nor are they a separate zone I can make clear.
Any help would be appreciated.
  • Richard HaseltineRichard Haseltine Posts: 108,949
    Have you tried using a Section Plane (from the Create menu) to chop the walls or ceiling off? If you turn on Clip Lights in its parameters (it's off by default) then reflections and lighting will still behave as if all the walls were still present.
    No I haven't tried that. I will try your suggestion. It sounds usefulc
