Highlight on transparency?
rickfoxxx74331700rickfoxxx74331700 Posts: 186
I applied to an area full transparency, but still appear the highligts that area. Why?
  • frank0314frank0314 Posts: 14,713
    Check and see what your reflect it set at
  • fixmypcmikefixmypcmike Posts: 19,692
    What application? In DAZ Studio, make sure under Specularity that "Multiply Through By Opacity" is on.
  • JaderailJaderail Posts: 0
    edited January 2013
    Select your Trans area/(item) in the Surfaces Tab and make sure all Settings are at Zero for Specular, Refection, and Ambient. Set all those to NONE if they load a Map file as well. Then do a test render for just that Area.
    Post edited by Jaderail on
