Uncategorized Content
Is there a way to search of Uncategorized Content that is in the Poser Formats folder?
I am going through the long process or organizing all of my stuff and have created an extensive library of user created categories. Categories - Default - Unassigned doesn't show anything from the Poser Formats folder as far as I can tell.
Thoughts or Suggestions? Thanks!
  • fixmypcmikefixmypcmike Posts: 19,705
    Have you done a scan for new content? Content should appear in Unassigned whether it's in Poser or DS format, unless it has metadata (and therefore has been assigned within the other Default categories). Does the content appear in the Poser Formats section correctly?
  • matt_e8d6faf681matt_e8d6faf681 Posts: 0
    Yes. I've used the "Scan Known Directories for Files" option with the following settings...
    It doesn't find hardly any content at all for the unassigned tab and nothing that isn't Smart Content.
    316 x 205 - 29K
    Nevermind - looking in the wrong pane - it the Content Library it did finally find everything. I think the Only New Items might have been the issue.
