Duplicate Formulas Found error...How do I get rid of it?
I originally installed G3F via connect, but had issues with Headshop, so reinstalled her and other via DIM. No problems until the recent Daz Studio update. Now when I load G3F from the DIM install, I get a "Duplicate formulas fond in files. Make sure that the content is properly installed. See the log file for more details." error.
This error doesn't seem to affect anything. I can hit "ok" and G3F still loads fine. I'd just like to get rid of the annoyance.
Also, where is the log file they mention?
Thanks for any help!
It is an item that returns every now and then
Best do a google search for it.. there is a script that may correct the problem by Richard Haseltine
https://www.dropbox.com/s/78mi1zh8p7udsgx/Fix Duplicate IDs.zip?dl=0
mentioned in this thread
https://www.daz3d.com/forums/discussion/740/daz-studio-4-5-fix-duplicate-ids-script
Duplicate IDs and Duplicate Formulas are not the same - the formulas error should not be afecting newer content, older content should have been updated long-since https://helpdaz.zendesk.com/hc/en-us/articles/207530043-How-to-fix-the-Duplicate-Formula-message
Thanks all. I did search Google and the Forum here...but, didn't come up with either of the quoted threads. Thanks for reposting the links!
So, my issue is with G3F. How do I go about uninstalling the version from Connect? I've looked through the Connect menu in Studio and don't see any Uninstall buttons.
i found and looked through the log file but saw nothing to indicate the issue.
I went so far as to uninstall and reinstall both Studio and G3F, with no change. I get the same "Duplicate Formula" error whenever opening G3F. This has happened only after the last DS update. Before that, the two G3F folders seemed to pose no problem other than taking up extra space.
