Need help with luminosity for Modo
HellroyceHellroyce Posts: 0
When I import my Daz character into Modo as .obj the textures are really pale.
I read that you have to change the luminosity in Daz from 1 to 0 before you export it
to Modo. Can anyone tell me exactly where I can find the setting? Really starting to pull my hair here.
Thanks
  • Richard HaseltineRichard Haseltine Posts: 109,502
    The luminosity setting is in modo, select the material in the Shader Tree and look on the Material Trans tab under properties:
    372 x 692 - 53K
  • HellroyceHellroyce Posts: 0
    Great! That fix it, with some tweaking on the shaders in Daz.
    Thank you friend, I really appreciate the info.
    Cheers!
