water plane render
edited January 2013 in Daz Studio Discussion
How to do water plane render in daz. I mean it works perfectly in poser but not in daz
Post edited by witcherask_a3dd58a1c6 on
  • BejaymacBejaymac Posts: 1,965
    edited January 2013
    Attach your images to your post instead of uploading them to an image host site, especially not one with porn adverts and scripts.
    As for the question, Poser surface settings and lights equals crap renders in DS
    Post edited by Bejaymac on
  • edited December 1969
    how can i achieve good water render in daz like the one in poser image
  • XoechZXoechZ Posts: 1,102
    You have to use water planes that are made for DAZ Studio. Look at the shop, I am sure you will find some.
    edited January 2013
    There are far easier ways to accomplish what you want. Use a water plane and add a displacement map, ensuring the primitive has enough divisions to accommodate the needed complexity. You can then add reflections (tinted depending on the type of water) as needed.
    The surfaces tab in Daz controls all the various aspects a surface can provide. For more advanced stuff you can use the shader mixer tab to create your own.
    Edit: Here's a very quick example of what can be done with simple refraction, and displacement. Obviously with more time and a proper displacement map (I'm using a noise map in this example) it will look far better than this 2 minute example.
    885 x 884 - 1M
    Post edited by Herald of Fire on
  • SzarkSzark Posts: 10,634
    That water plane in Poser does it come with a displacement map...if it does you can use that in DAz Studio but you will have to adjust the settings.
    Also googleing creating water in daz studio got many results that show how to do water in DAZ Studio
    The Poser image looks like it's an environment sphere, and if that's a displacement map it's a hell of a big one to get that much detail over such a large area.
    If it's a product your using then a link to it might help give us ideas as how to best copy it in DS.
  • adamr001adamr001 Posts: 1,322
    Here's an easy method for making water planes in DS: http://afina79.deviantart.com/art/Creating-Water-In-Daz-Studio-159064896
