Looking for textures for Eastern Dragon
http://www.daz3d.com/eastern-dragon
I am looking for additional textures for this dragon.  I have the one it came with and the Eastern Jewels http://www.daz3d.com/eastern-jewels)  which has a lot more options than the store page actually shows
But .. I'm looking for a greenish dragon, or other colours,  that is less saturated than the Jewels one. Has anyone seen any ?
LM
    only last night i was wishing for similar jewels textures for mil subdragon or dragon 3.  as carrara shaders.
  • I've never seen any addon textures for the Eastern Dragon, other than the ones you mentioned. Nor have I seen any for the variety of one-off dragons that DAZ created before Dragon 3. I'm guessing that the market for these would be pretty small, but additional textures for these would still be nice to have.
  • mmalbertmmalbert Posts: 412
    edited February 2017
    Edit: Whoops, I think it was just poses I bought elsewhere. Sorry about that!
    Post edited by mmalbert on
  • I have a feeling there was at least one set at PoserPros. Which is of no help now, unless you bought it and forgot about it (assuming it wasn't the Eastern Jewels set that is now here).
  • If you can't find textures, try hitting the Easter Dragon with colored lights.  You might be amazed at how the texture on the dragon changes.  I was pleasantly surprised when I was working on some shaders and I rendered out the exact same dragon with different colored lights from one of the iRadiance packs and the color of the dragon totally changed in a nice way.  Not sure if you'll get the look you want but it might be worth a try.  I used the dragon in Iray, but if you're in 3Delight a colored light in there will probably do the same thing.
    In the image below, the same dragon using the default texture in both.  The only difference were the colored lights.  No postwork.  I had one look green when I was going through the lights, but I didn't render that one because it didn't go with the colors I wanted for this project.
  • GrazeGraze Posts: 418
    At one time I made the Eastern Dragon green by changing the color (ambient? diffuse? I don't remember).
    By changing the color to YELLOW, it mixes with the default blue texture to make a green dragon.
