export from daz studio with iray settings to 3dmax
Is there any way to the export scene with the iray settings into 3Dmax and render in 3dmax with iray engine with the same settings to get same Results ?
Like that in vue xstream
Which format are you using to export/import? While both D|S and 3DSMAX use the Iray render engine, the format you're using to go between them might not — and the two programs might not use the same setup for actual materials. I know I frequently have problems with exports from 3DSMAX, to the point that it's usually easier to rebuild the materials from scratch once I've successfully imported into D|S.
