Downloading Materials
Hello, new user and I have a question as I'm trying to figure things out.  I've found a little of this subject but still can't determine out how to get over this problem.  I purchased a set of hair for my Teen Josie 7 figure and the hair selection has one selection of the color hair in it, which is easily loaded by double clickiing on it.  However the remaining colors and shapes of the hair show up in the Materials section, and double clicking does not load them there.  What particular step am I missing as since the hair is noted as being compatible with the Teen Josie figure I think it should download as well?  Also I bought some waredrobe for the same figure and it ALL showed up in the Materials section and I'm not able to load any of it by double clicking.  Thanks for any help.
  • scorpioscorpio Posts: 8,533
    It sounds as if you might have bought some texture sets for things rather than the actual items, can you link to the items you have or give the names and where they are avialble.
  • SixDsSixDs Posts: 2,384
    edited February 2017
    Or you are forgetting to select the hair in either the viewport or the scene tab prior to clicking on the desired colour? As for the second issue, it is quite common for the actual clothing object to be separate from the textures or materials. You need to locate the actual item, under clothing, probably, and apply it to the figure, then select the clothing in the scene and apply the desired materials.
    Post edited by SixDs on
