Viewport slowness
Geminii23
Can anyone let me know if there is a way to speed up things in DAZ. I noticed that a lot of scenes I previously created in older versions of DAZ seem to take forever to load now and the viewport is extremely sluggish when trying to move around.
I am on a 6-core with dual GTX 760 4GB GPUs. I also have 32Gb or RAM.
Thanks
Do you have the current driver for your GPU.
Try going to Edit>Preferences>Edit tab - the Display Optimisation setting can usually be raised from its default.
I had the Optimization set to Best, but I can drop to better. I also checked and installed latest Cuda drivers. I ran a LuxMark test on my system and my score is just over 10K. I guess that is decent but not sure. Also, each of my GPU have 1152 cores. Isn't that sufficient?
Would bumping up to 64Gb ram (my current ram is only 1333mhz also) make a difference or is the viewport solely driven by GPU?
