Can you alter textures in Daz Studio? Texture Atlas?
JENR8
- I would like to alter some things - make them my own skin. IS this possible? I know you can in Poser but haven't altered textures in DS. Do you do it within or need a secondary program.. I found a screen grab of texture atlas online, but are there other ones? IS texture atlas in DS or an older version? If so, can I save the texture to a folder and alter in Photoshop?
- Once altered how do apply the texture for the desired effect?
If you just want to change the image maps itself and not change any UV maps you can just make a copy of the existing image maps, modify them and select them instead in the surface editor, if you look at any surface that has an image map as a texture you will see that you can select the image to use there.
The texture atlas is when you map all textures into one single imagemap, this require that you change the UV maps.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/chapters/textures_surfaces_and_materials/start
https://turbofuture.com/graphic-design-video/How-to-Make-Custom-MATs-for-DAZ-Studio
