Are you rendering it in Iray instead of 3DL? Correct me if I'm wrong, but I think this is a 3DL-only product. I tried using !Rock Shader Base.duf on a sphere in iray, and it doesn't generate the rock shape or same material (although it did render with A material, just a smooth one with a completely different appearance.)
Which rock shader set are you using?
This one...
yep....3 delight.....proved to get me on my way. thank you a bunch.
