Does anyone know if pwtoon works with DS 4.9?
JENR8
If so, how do I access? Is this the best option for toon renders?
JENR8
It should, the prsets for applying it are in Shader Presets>pwToon_DS4 in the Content Library, under DAZ Studio Formats and then the folder you installed to. You apply shader presets by selecting the model and the surfaces on the model that you want them on - as long as they aren't behind other surfaces (as in the human eyes) this is easiest with the Surface Selection tool.
I went in and looked and I used the install manager but it must have not installed properly. Do you have suggestions for a manual install or perhaps it is not installed in the correct directory via install manager.. Everything else seems to be installing properly.
Right-click on the item in the Installed tab of DIM and select Show Installed Files. That should show the oflder they were installed to, at the top, and the list of files and their relative paths within the install folder.
Last question... Do you know if you press the render button to get it to render or what am I doing incorrectly? I press the pwtoon various choices but do not see anyting in real time or other.
A shader like pwToon will not usually show in preview, you do have to render (in 3Delight) to see the effect.
