to correct the distortion in props
2»
  • va-silyva-sily Posts: 52
    hi, I want to make a smart prop, replace part of the face to a new prop as to make the original part of the face disappeared, replaced prop put part of his face? We must do as well as the genital area - the original part disappears, and in its place stands prop genitals.
    777 x 837 - 182K
    777 x 837 - 197K
  • Richard HaseltineRichard Haseltine Posts: 109,083
    If you are wanting to create a GeoGraft then the replacement must match the zeroed shape of the figure, not a morphed or posed state, and the vertices around the edges must precisely match the vertices around the mesh you want to hide..
    yes, I want to do it, can you explain what method?
  • ben98120000ben98120000 Posts: 469
    Link to geografting tutorial: http://www.daz3d.com/forums/discussion/24555/
    To add, in 4.6.3.50 version of DS "Polygon Group Editor" tool was renamed to Geometry Editor.
    Thank you!
    hi, please help me understand., I create GeoGraft , everything worked, but when it moved to zbrush to make morph nose, then back to DAZ, then morph does not apply, .GeoGraft now without a morph, tell me why?
    if you do not fit to the head of Genesis, then morph works separately as soon fit to the head, then morph does not work. why?
    777 x 900 - 155K
    777 x 900 - 144K
  • JaderailJaderail Posts: 0
    Did you save the Morph into the GeoGraph item? For this to have worked you build the Morph on just the GeoGraph Mesh and then you add the Morph to the GeoGraph item in DAZ Studio as a Morph asset of the Geograph. And the Morph when created must not move the Base Blend mesh that graphs the mesh to the figure.
    But For just a Nose morph why do you not just build a nose morph for the Figure? A GeoGraph is overkill for just a morph. GeoGraphs are more for adding more mesh to the figure, not for shaping the figure only morphs.
    I want to make a GeoGraph with morphs. GeoGraph to change himself. not figure genesis. example of the genitals. genitals replaced GeoGraph and it has morph
    I want to create part of the face-changing nose. mouth, chin, for example.
    The Gens are a GeoGraph because the figure has no Gens without the GeoGraph. The figure has a face and you can Add morphs to it without first building a GeoGraph. But if you wish to do so your free to build your Graph. I just do not see the need myself. All my face morphs I bought are just Figure Morphs and none came with a Graph. Here is just a small part of my Genesis Face Morphs.... No Graphs needed.
    499 x 895 - 123K
    do not misunderstand me, I want to apply morph only to GeoGraph, but do not understand why it is not apply.?????????
    801 x 867 - 135K
    801 x 867 - 162K
    What are the morphs called? Are they being zeroed, or do the numbers remain but fail to have an effect on the mesh?
    First it is geoGRAFT because you are grafting a new bit of mesh geometry into the base mesh geometry. Second it is still unclear as to why you are not just morphing the figures face, the examples you have shown don't require geograting.
    edited February 2017
    hi. I need your help. I did the graft  figure. . but when i do fix to the Genesis it get such defects. not the same faces at the neckline. how to fix it?
    Post edited by va-sily on
