Question about hair on Gorilla, etc.
JENR8JENR8 Posts: 100
edited February 2017 in New Users
  1. I own several characters with hair - Gorilla, Ape World, and a few others. How do you make the hair lengths? I see the sample icon the hair is green. Is it possible to add more hair to an object or is a secondary program requirred? I understand Carrara has a hair builder, but would like to stay in DS.
  2. Is there a way to make characters younger in size? I like how Genesis gives this option.. suggestions or do you need to stay within Genesis and use the baby model attributes?
Post edited by JENR8 on
  • 1. The green hairs are just the guides, showing how the hair will look. If you render with 3delight the full hair will appear - if you are using Iray then you need to use the Look at My Hair plug-in to export an OBJ version from the posed figure. The plug-in is also how you edit hair length.
    2. Not built in, but look at Zev0's Growing Up products for the different versions of Genesis.
  • JENR8JENR8 Posts: 100
    Thank you Richard!
