No response from keystrokes typed in fields Win10
Using Windows 10 64 bit, randomly when I type in numbers in fields such as transforms, nothing happens for several seconds.  Like 10 or 15.  I've had this problem in other applications (web browsers, notepad) but DS seems to be the largest offender.  And yes it will do it with the draw style NOT in iRay mode.  This is maddening and I've got to fix it.  Any insight would be appreciated.  Haven't found any relevant info on the Logitech forums.
  • krickerdkrickerd Posts: 225
    Okay this seems to be a Windows 10 problem, based on what I've read from the Microsoft forums.  Some people have even used WIRED keyboards and have the problem randomly.  Folks, this in 20 freaking 17!  We definitely shouldn't be subjected to this kind of crap at this point, Windows or whatever.  There is zero excuse and I've no tolerance.
  • They changed a lot on the lower levels driver layers in Windows 10 so many old drivers (not just OpenGL) will not work on Windows 10, make sure you have a keyboard driver for Windows 10 and not some old lef tover rubbish since before you updated to Windows 10, otherwise it's not a DS problem anyway, hope you get it solved.
