Invisible Background
wizard1200wizard1200 Posts: 240
edited January 2013 in New Users
If i render in Daz Studio 4.5 Pro without using a background the standard background colour is always visible in the render. Is there a way to set the standard background to invisible?
Post edited by wizard1200 on
  • JaderailJaderail Posts: 0
    Save as a .png. Only way I know of.
  • Richard HaseltineRichard Haseltine Posts: 109,465
    edited January 2013
    PNG or Tiff - both store an alpha channel which an image editor or viewer will either treat as transparency or as a saved mask (alpha channel). Though if you are going to use that it's probably a good idea to change the background colour, to black or to a colour that matches the background the image will appear on. You can change the colour via the Viewport option menu - click the menu button in the top corner and select Background colour....
  • wizard1200wizard1200 Posts: 240
    edited January 2013
    Thank you very much for the fast answers and for your help.
