Opitex Collisions
Hello all,
i'm not sure why a drape will not collide with a surface that is selected in the collision dialogue box?  As you can see, the opitex figure drapes on the torus, goes thru the table and drapes on the plane but not the table. Thanks
  • djigneodjigneo Posts: 283
    The draping cares about how hi-resolution the geometry of the item is. In this case, I'd guess the table is low-res and the cloth isn't finding anything to collide with.  What I'd try is creating a higher-resolution plane and aligning it with the surface of the table and setting it to invisible, then have the cloth collide with that.
  • j_stnkj_stnk Posts: 205
    Thanks! that was it.
