Help with Iray render speeds?
I've been using redshift and cycles.. but I got tired of the workflow from daz to houdini and blender. So I started using Iray and my render times are like 20x longer.
I'm using two 1070 and a 980ti. Anyway to make it faster? I've set it to speed mode and using optix.
2017-02-06 00:08:39.984 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00242 iterations after 149.774s.
2017-02-06 00:08:45.044 Saved image: C:\Users\Victor\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2017-02-06 00:08:45.101 Finished Rendering
2017-02-06 00:08:45.138 Total Rendering Time: 2 minutes 36.0 seconds
Another scene I was testing took 30 minutes before it was nice enough to downsample, in cycles it took 5 minutes.
  • SzarkSzark Posts: 10,634
    2 X 1070 taking longer....you don't say what version of Daz Studio you are using, as 1000 series cards only became usable in the latest release.
  • the latest release.
  • grinch2901grinch2901 Posts: 1,247
    Your posted render doesn't look like an IRAY render to me, looks more 3Delight; for example no shadows under things. Are you sure you have Iray selected in the render options?  I guess you do because the log extract you post says IRAY but it also says render completed in 2 and a half minutes which is pretty good.  Can you provide some more specifics?  What your render settings are, for example?
  • I usually use default settings with speed optimization set to scene only lighting and, using mesh lights.
