Adding to Cart…
Amen on both points!
I use daz internal search(s) only as a first-pass content finder. However it's limited. I'm not sure if it's a 'starts with' or 'contains' search. For example, when I search for eraser or erase, it brings back a couple of eraser props. However it doesn't find any props when searching by eras.
So, I usually employ Agent Ransack (which is free). Just right click My Daz 3d Library and select to run agent ransack in windows. OR your cloud connect library, whichever you use for your stuff. I searched for eraser and even found a cool 3rd eraser in a classroom prop set (another limitation of daz internal search - it doesn't seem to dig through the sets, only individually saved props). Agent ransack does a contains search by default and is fastest when searching filename (often the files have a name that makes sense). It can even search within the files, tho it may take a little longer.
They are tools.
Use whatever suits you best. There is some good advice in the thread to try and sort out what is causing you issues.
I'm biassed against Connect, but imo it seriously sucks.
I like tools to do what I want, not the other way around; and Connect was someone saying - do it this way. That just irritates me.
Thanks for that one. Wasn't aware about the rendering images panel being left open.
When an unfinished render is left open, it's still holding on to the gfx ram it needs in order to render. If you have even a decent gfx card, that means that your next render may default to cpu if the ram taken by the render from the gfx card is large enough that not enough is left over to render the second open render window. I hope that made sense ;)
Laurie
That's because every render has a panel hidden that you can adjust bits on it.
...same here, but mainly because I am not into having my content proprietary to just one programme. Granted that cannot be helped with G3 (doesn't work in Carrara either), but to have props clothing and hair only usable in Daz is too restricting. I alreay am somewhat miffed that new content is being released with Iray shaders only (though there finally is a free script to help with converting to 3DL). Nothing yet exists for Poser Fierfly/Superfly or Carrara though.
