Genesis 3 Female Belly Button PROBLEM
Hi there I'm haveing an issue with Genesis 3 Female im working on a character to sell. but im haveing problems with G3F belly button. So i've made the morphs in hexagon and sent them to Daz studio via bridge. But each time I add the morphs the belly button on G3F becomes more inverted. I used the standard G3F figure (no morphs) to make my morphs and I haven't made any changes to the navels geometry or used any morphs and its not the skin texture. Can anyone help me.
Are you sure there were no morphs applied? That looks very like the effect of making your morph with the Navel morph already on.
Check to see whether you've also got problems with the teeth. This looks a lot like an issue that can arise if you don't zero the pre-dialed morphs before starting work.
Thanks for the advice and it is the default morphs that were the problem and I have corrected it.
