Thx Richard. DS GUI has shrinked. SOLVED
Jerife
Help needed please.
I have a problem with DazStudio on Windows 10. The program GUI has shrinked and disapeared from the screen. I can open it but the area is so tiny the only thing I can do is close it
It seems I made that preference size without noticing and now the program remembers it
I have already:
- Switched to one screen or two (I normally use laptop+another screen)
- switched screen to vertical or horizontal (and look for it)
- changed resolution 1366 x 768 recommend to all the other posibilities
- deleting Ds4.9 reinstaling from DIM 4.9.3.166
- opening directly from a file
DS opens asks me if I want to save it when I quit, the bar shows is open but I can grasp it. How can I cancel that memorized size?
I am mad now and lost all day with this
Help please
Post edited by Jerife on
A question, has clicking on the square next to the closing X had any effect (I marked it with a questionmark in the screnshot)?
Also, when you hover over the corners of the Gui, does it five you an arrow with two poiters? If yes, does the following work: Click left and keep the left mouse button pressed, and slowly drag outwards.
I apologize if you have already tried these options.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/specific_ui/screen_size_fhd/start
Download this script, optionally adjust the size set in text editor, and double-click.
Nope to both BeeMKay can't maximize, nor minimize btw, only close. Can't resize the window either
Thanks Richard, dwloaded and will try but I know nothing about scripts
Fiddling with the cursor key arrows I've achieved to open this panel. Maybe is here where I can restore size? Maybe I can open the correct tab? what exactly must I click?
Lovely script
Thanks Richard
It's one of Rob's sample scripts, I was just pointing it out as a solution.
