Windows 10 "new" error..?
..Hello how can I simply fix that?
  • What security software are you running? Have you in fact installed PostgreSQL? Were you using PostgreSQL before, or were you still using Valentina to run the Content Management Service?
  • MusclemanMuscleman Posts: 3,099
    Avira for security and I jus pass from Vista to Win10 in one night....so just use the normal D|S reinstall from the last version relesed.....I miss some?
  • I thought DS itself - if you are using the current version - would now install PostgreSQL but to be safe make sure it is listed as installed in DIM.
    Ok thanks, try it now!
