DAZ Catagories DB
Blackbirdx61
I've learned alot since I first Started with DAZ;
What I would like to Do is Replace my Default DB Tree with my Rebuild DB Tree.
Unfortunately it does not seem one can rename the Default Tree; or do much else with it. Any suggestions would be welcome.
I did look at editing the xml in the user Data but the Rebuild does not seem to have been copied there? Go Figure.
The default categories are pretty much unkillable. You can't delete them or rename them, all you can do is add your own custom categories and folders.
Thanks SK.
