Depth of Field - any tricks to speed up render?
2»
  • For example, while everybody says "never use Ambient feature", yeah... screw that!
    I actually use it all the time, usually keep it low though, when I want to quickly show my models (animated or not) I use Ambient Occlusion only with it (no other lights or SkyLight), with a right combination of high ambient like 75(!) and indirect light on like 150 and proper occlusion radius it can look pretty good, example below.
    smiley
    1280 x 550 - 172K
  • DesertDudeDesertDude Posts: 1,239
    Cool FifthElement, thanks for the info!
  • PhilWPhilW Posts: 5,161
    Ambient on its own looks dreadful (IMHO), washing out a scene with as much light down a crevice as on an open surface.  More or less the ONLY time that you should use it is together with the Ambient Occlusion mode, when it is a faster alternative to using Full Indirect Lighting, and it can then produce some fast and good looking renders.
  • DartanbeckDartanbeck Posts: 21,984
    edited January 2017
    I use it and AO quite a bit too
    but this is one awesome result!
    Very Cool!
    Post edited by Dartanbeck on
