GPU memory question
sarge74
I've noticed some odd things about Iray and my GPU. When I'm rendering a scene (simple architecture, two gen 3 figures and HDRI lighting) I can get it done in under twenty minutes. I ususally am rendering several as part of a comic book. But after a bunch of renders, it seems to slow down, and sometimes, kicks over to the CPU (which then takes over an hour). I will cancel, save scene and close Daz. I then relaunch Daz, open the same scene and viola! back to rendering with GPU in under twenty. Same scene. I've worked at making sure I build scenes that don't over power my GPU so that I can render quickly with IRAY (Which is amazing by the way), but I don't understand why I need to relaunch after a while. Any Ideas?
Windows 10, Nvidia Gforce 1060, Daz Studio 4.9 Beta (becasue the regular release doesn't support the Nvidia 1060)
Sometimes the GPUs memory isn't released after a scene is rendered or canceled. It seems to be a bug.
You could put in a bug report.
Right. OK. I guess I should do a bug report. I was just wandering if anyone else had experienced this and if maybe there might be a setting or something I'm not aware of that would help.
Thanks for the replies.
I get the same issue when doing multiple renders or animations with large scenes.
The workaround for me is to disable Optix in Render Settings > Advanced.
I'll try that. Thanks so much for sharing. Much appreciated!
Happens to me every time on subsequent render attempts even if I cancel a render midway (Note: my scene memory often exceeds GPU memory). On observing the the GPU memory utilization through GPU-Z, I can see that the GPU memory is indeed not being released upon exiting the render. This was happening even with the earlier version of Iray. As the current version of Iray dumps more information in the logs, its easy to identify when this issue occurs.
The only reliable workaround apparently is to restart the Studio at the cost of reloading time of the entire scene.
Edit: The OptiX Prime Acceleration option is disabled by default for me.
Leaving the render windows of previous renders open also takes up memory.
This is not a general bug. As long as I close render windows, I can clearly see the GPU memory being cleared (via GPU-Z). All the time.
I've seen it. Same scenario as you, rendering a sequence of images as comic panels so everything in the scene is the same except pose and camera angle changes from render to render. Everything renders GPU for several panels and then, randomly, in one it will use CPU only and all subsequent ones render via the CPU. Obviously the scene fits in the card so it's a bug.
Thanks for the response. At least I'm not alone. Wonder if there's something that can help with this. It sort of takes you out of the groove, you know?
I've really only seen this if I don't close render windows from earlier renders.
It's my understanding that the reason leaving previous render windows open consumes GPU memory is that you can resume unfinished renders at any time.
(at least) One other reason: If a previous render is left open, subsequent renders will be faster because geometry,etc is already loaded. Works when you are tweaking lighting, poses, and so forth. Some advantage for materials changes as well. Previous renders don't have to run any longer than seeing the image appear (for instance a quick lighting check). I will often do a fast low res lighting check, then a full res render when I'm satisfied.
Yes. That's what's happening to me. I do not leave previous render windows open. That's not the issue. Thanks for your input Outrider.
The latest official release 4.9.3.166 (well there might be a newer one today) now supports 10xx cards. It might not fix your problem if you have a higher beta version.
Not sure what the beta number was when I installed. I installed it on Dec 20. So the new official release supports the Nvidia Geforce 1000 series?
yes
