G3F Clothing Cling
marble
in The Commons
Whenever I have a larger woman in the scene, any clothing tends to cling - especially under the breasts. Often it is so bad that I can't fix it with an external modeller. Smoothing doesn't help either. The mesh is actually crumpled and passing through itself. In short, it's a mess.
Is there a way to fix this? Autofit has its advantages but it also creates its own problems.
Hmm, well VWD let's you 'pull' the mesh out to straighten it. But that's like using a hammer to push in a thumbtack.
I suppose you could just not autofit it, and align it with the figure, perhaps a fraction smaller. Then turn on smoothing/collision against the figure to have it pop out above the skin. Not sure if smoothing/collision works tho when not using autofit, never tried it.
Finally there are some products like Zev0 fit control and Wear Them All which have breast/cleavage/chest morphs.
I have the Fit Control product so I'll see if that helps but I don't have VWD. I also don't know how to fit something without using auto-fit. I tried but it was nothing like the shape of the figure so practically useless.
