Rim Light Rig
Hello,
Has anyone used a Rim Light Rig set of lights: http://www.daz3d.com/rim-light-rig
Whatever I do I end up with the complete black figure or completely lit up scene?
Thanks in advance
  • BeeMKayBeeMKay Posts: 7,019
    That light set is for 3Delight render engine. Are you using 3DL, or Iray?
  • LlynaraLlynara Posts: 4,772
    edited January 2017
    Yes, I have it and love it. It is for 3Delight, not Iray. (Marshian's new Body of Light set does have rim lights in it, but they're different than these.)
    The Rim Light Rig is a great set with a lot of flexibility. I made this promo for my superhero series with it. The hair shaders are wonderful and easy to use. For postwork, I used Ron's Light Fusion brushes to add the energy effects.
    Post edited by Llynara on
  • Probably need to rotate the rig. If the lights are a group, select the group and use Y rotate in the parameters tabe to position the lights until you are getting the desired result in your preview window.
  • MarshianMarshian Posts: 1,465
    edited February 2017
    momirborocki- did you figure this out? I can help answer questions. Llynara- thanks for posting such a delicious render!
    Hello,
    Thanks in advance
    Post edited by Marshian on
  • KigeKige Posts: 1
    Hello,
    Thanks in advance
    Did anyone figure this out? I'm having the same problem but am dying to try this. It looks awesome! Is there a tutorial somewhere or at least something that shows settings? I see some are saying it is for 3DL and not Iray but I don't seem to have the option to change. Sorry for my ignorance and thanks in advance smiley
    There is a set for 3dl and another for iray, 2 different products, so match up the version with the render engine you're using. Check this out and let me know if you're still having trouble. I'm here to help
  • IceDragonArtIceDragonArt Posts: 12,759
    Kige said:
    Hello,
    Thanks in advance
    The set that is linked by momirborocki is for 3Delight.  Make sure you are using the one for Iray if that is what you are rendering with.
