MDL v RSL materials options? What is the difference?
Hi - I see some materials - like pony tail ties in hair - have MDL or RSL options. Should I be using one over the other if I am using Iray? thank you
For iray you want to use the MDL. RSL is for 3Delight.
MDL is for Iray, RSL for 3Delight
Ah - thanks!
Hi! And what does "MDL"/"RSL" meen?
MDL = Material Definition Language, as developed by nVidia for their Iray render engine
RSL = Renderman Somethingmumblemumblemumble Language (S for Shader?), with Renerman being the render engien that 3Delight is compatible with.
Thanks a lot!
P.S.: RSL - RenderMan Shading Language. I have found out whith your help.
