Content Library Disappeared. HELP!!!!!!!!!!
PandyGirlPandyGirl Posts: 105
So firstly, I have two DAZ3D folders in documents, sometimes can be annoying so went to adjust one and changed the wrong one, didn't kick in until I opened up Daz Studio to work on an outfit to finish up. Well my content library was missing EVERYTHING. So checked pathways etc. then went and looked in documents adjust folder back to original name. restarted Studio.. STILL no content showing in the content library tab.
FYI nothing was showing in the smart content tab either, but I have never used that tab. well after MANY hours of searching and reading other posts ( which all pertain to the smart content tab ) I finally got the smart content tab to show stuff. BUT There is still NOTHING in the content library tab.
Really could use some help figuring out how to fix this, ;(
  • Richard HaseltineRichard Haseltine Posts: 108,568
    I think you've closed the directory list - click the darker grey box in the bar under the search box and it should be shown again.
  • PandyGirlPandyGirl Posts: 105
    ARE YOU KIDDING ME???????? I have been freaking out for the last god knows HOW long since like 15 hrs over this, and reinstalled and uninstalled and moved and OMG.. KILL ME NOW..
    Thank you.. I am going to go jump off of a cliff now.
    heh, you are far from the first person to be bitten by the ability to collapse parts of panes.
  • KeryaKerya Posts: 10,943
    If you didn't jump before - NOW is not the time to jump - just after Richard helped you!
    That would be really ungrateful!
    LOL
  • editor-2744080editor-2744080 Posts: 3
    I know this is a dumb question, but which darker box are you referring to? I have the same problem and have no idea what to click on to fix it.
  • fixmypcmikefixmypcmike Posts: 19,702
    It's directly above the word "NONE".
  • I a having the same issue also.
    The box above None just opens a file structure of "the range of assets” .
    I have attached two images [before /after]of clicking the box directly above- the word "None".
    1056 x 848 - 46K
    1038 x 816 - 72K
    It looks like you have the folder list set to Side-by-Side, in which case the box you need to click should be half-way down on the left.
  • Thanks alot for your prompt response.
    Half-way down the left just shows me the "Format Tree" [please see attached]
    What next ??
    1066 x 1996 - 129K
  • Feel dumb, my bad.
    I guess they have disappeared from the Category level, ie Animals but show up in subcategories.
    Thanks for the help.
