Opening Duf Files in Notepad, newly created ones gobbletygook
Rae134Rae134 Posts: 50
Hi, not sure if this is the correct place to ask this. But I've just created some new Mat files and when I open it in Notepad it doesn't look the same as the older files.
I've attached copy of what it should look like (the readable one) and a copy of what I now have (looks corrupt or encrypted or such?)
I haven't done anything different to the way I normally do it (and the mat files still work fine for me).
I'm running Version 4.9.3.166 Pro Edition 64bit. (I did try re-saving them in 4.8 but got the same gobbledegook)
Edited to add: Any way of removing this post?  (I stupidly had compression checked :P)
Post edited by Rae134 on
  • You probably had the Compress file option checked - in which case you can uncompress using the Batch Convert pane inside DS or an archive tool (I usually use 7Zip since it has a right-click option on the file).
