Characters Deforming
I recently upgraded my computer and installed DAZ 4.9.3.166. All seemed to be working well until earlier tonight, when I noticed my characters being deformed. If I load G3F base and apply a character it will be deformed. If I load one character then load another the first will deform. In the image below I loaded Tween Julie 7 and it loaded properly, When I loaded another Tween Julie 7, however, the first one deformed as shown on the left in the image below. I did purchase and download the zone smoothing for G3 bundle today but uninstalled it and am still having the same issue. I also uninstalled and reinstalled DAZ Studio. Can anyone help, this is really frustrating.
Thanks in advance.
    Is the first figure still selected when you load the second figure? That has been known to cause Weird Stuff™ to happen.
  • I know this is a little late in the game - but check in "Currently Used" in the parameters tab and see if the deformed character is loading some other morph. I've seen a problem with a morph loading with a parameter when you load a character, when it should be zero. I did some research and other people in the forums were experiencing the same thing. The solution for me was to disable the morph, although you can generally just slide the offending morph back down to zero and your character will appear like they should.
  • This is still valid today (November 2025) Had a bad morph with a G9 character (Vo Suzu) that hosed the default G9 base character. Just look under currently used in peramiters and you will find the offending morph.
