Content search with DAZ4.5 seems to be case sensitive
Content search with DAZ4.5 seems to be case sensitive. With 4.0 it was not, which was much more convenient. Does anyone know if there is an option to make the search case insensitive?
I just tried this, and my version (4.5.1.6) does not seem to be case sensitive. Whether I type in 'the freak', 'The Freak' or 'THE FREAK' , I get exactly the same results.
Can you explain exactly what you are searching for, from where (Content Library etc?) and what the search item is called?
I am getting what Jimmy gets, same version too.
I sometimes feel samething ^^;
but maybe I need to understand some rule to serch files.
eg If I serch by "Aiko3" , I am so embarassed because,, CMS just find Aiko3 face pozes for me,,
only 38 files and almost about Face poze, they can not find Aiko 3.cr2 too ^^;
but if I serch by "Aiko 3" I get almost everything which I installed and reffered to Aiko 3"
474 files,, I get now^^;
but it is funny,, because there are ,genesis expressive face pose preset files too.
so I check these files by content db editor,,, they tagged "Aiko" too. why? ^^:
I never tagged such word for these files. never.
on the other hand,, of course they only assigen with genesis, not A3,
so they can not be shown in smart content, if I select Aiko ^^;
Thanks for your prompt reply. This morning the search works fine. Yesterday, after the installation, it definitely was case sensitive. I spent quite a bit of time testing it to make sure. For example, if I typed "grass" I got only two results, but if I typed "Grass" I got dozens of hits.
I'm glad that it works now, but that it changed is a bit disconcerting.
The search feature in the Content Library (and other places) relies on the CMS (Content Management Service) running properly. It is a process that is loaded by the OS before DS4P even runs.
If you look at the Task Manager in Windows, under Processes, you should see it. It is called ContentManagementServer.exe, and Smart Content relies on this as well. You may have had a blip of some sort with the CMS, and it is now reloaded and working correctly.
Hm... I find DAZContentMangementService under Services but not the Content MangementServer.exe under Processes.
Perhaps something is still not right. I also don't think Smart Content is working properly, although up to now it's something I've not used. I've always found content by searching the Content Library. Now if I go to Smart Content it seems very little is there. No Genesis figures, for example.
No don't worry CMS is under Services NOT Processes.
I am not very good at troubleshooting Smart Content issues as I have trouble getting my head around it all and I haven''t had much trouble with it myself...mind you I don't use it much prefering the Content Library Pane instead.
It is under both on my PC, Win7 Home Premium. It is a SYSTEM process, and you need to check the box 'Show Processes from all users' to see it.
Thanks! Yes, I see it now.
It is under both on my PC, Win7 Home Premium. It is a SYSTEM process, and you need to check the box 'Show Processes from all users' to see it.Thanks Jimmy for the tip. :)
