teeth problem with justin
just cannot morph the teeth to acceptable form. Why are they that thin? Like this, the justin figure cannot be used for anything really. How to fix that? Can I somehow fix that, or is this a bug with the figure?
Also, why are all the tooth textures that bad for all figures? Are there any ok textures for use with genesis anywhere?
Thanks for help.
There is a thread on this here: http://www.daz3d.com/forums/discussion/13686/P75/
And a Bug Report:: https://bugs.daz3d.com/view.php?id=48671
There is a bug report on that. Note: the bug tracker does not work with your DAZ forum/shop account, but needs a new one.
Teeth Bug
Also some discussion in the render thread and some workarounds.
Genesis YT Render Thread
Edit: I am too slow for Jimmy :D
Thanks both, still unable to fix, assume have to return the teens until DAZ has fixed that.
I am going to hang on to mine. The next time you buy them, there may not be as much discount. I am sure that DAZ 3D will come through with an answer very soon.
An administrator split and moved the thread to here http://www.daz3d.com/forums/discussion/13808/
Feel free to add a note to the bug report expressing your concerns.
