Looking for Poser Freebie Mosquito
in The Commons
Hi! I'm looking for a mosquito Poser Freebie but I didn't get to find one. Do you know where can I get one?
You could try looking here:
http://www.daz3d.com/forums/discussion/17598/search-housefly-cockroach-or-larva-freebies
Thank you but I've checked out that discussion before and even they have many bugs, there isn't any mosquito, (at least not a freebie). :(
Not free but cheap if you are a PC+ member: http://www.daz3d.com/mosquito
I think this can help me. Thanks! :D Anyway if you someone know a freebie one, I'd thank you let me know. Thanks again Charlie Judge! :D
If you can live with a prop - no posing: http://archive3d.net/?a=download&id=49492c7b
Be aware you will need to convert that one as well, as it comes as a 3ds model. THere are some free conversion apps around.
I see, thanks, althought I downloaded, I need a figure because I need to make some animations, that's why I need a figure, but anyway, thanks for the imformation! ;) I'll see if I can find a figure before buy the Daz Mosquito.
Unless it is for use in poser, as the OP mentioned in the 1st post. Poser can read the 3ds file. (It is a static prop however....and with default import settings loads extremely big, need to scale down to 0.1% or less :) )
Aha, I had missed that in the first post, Yes Both Poser and Bryce can use DS as is. I thnk Carrara also. Still there may be some DS users reading this.
Thank you, but I need a figure which can move their wings and have different poses because I need to make an animation with it. If someone knows about a poser freebie, please let me know, in the last case, I'd have to buy the Daz Mosquito, but sincerely I wouldn't like to buy it if there is a poser freebie around there. Please let me know guys! ;)
