A Daz Studio Rookie needs some advice/help in 3 areas
I need some advice/help with the 3 following questions…
1)  I’m used to working in Hexagon, Carrara, CorelDraw where we have pretty large “viewpoint”/workspace & in comparison Daz Studio has a pretty small
“viewpoint”/workspace, is there a setting or a way I can adjust that into a larger work area?
2) I’m trying to do an ocean scene is Marshian’s “Ocean Wide” at ( http://www.daz3d.com/ocean-wide ) with the Orca(s)/Killer Whale(s) from ( http://www.daz3d.com/orca-killer-whale ) but I’m having trouble with getting the sky, if I add my own skydome every renders into a “Black Screen”. Is there something that I’m doing wrong?
3) Also on my ocean scene I some advice on which set of brushes I need to do the water Effects off of the whale seen in the main picture on Orca(s)/Killer Whale(s) from ( http://www.daz3d.com/orca-killer-whale ) the Brush Sets that I’m referring to are from Deviney’s Ray’s Water Bundle (http://www.daz3d.com/rons-water-bundle )
Thank you,
  • srieschsriesch Posts: 4,243
    1) Not sure if this is what you mean, but you can move the camera back from the center of your view, or create a new camera to use then change the focal length to make it wide angle?
    2) Are you using Iray (the default render engine) or 3DL?  Research iray and skydomes.
  • EtriganEtrigan Posts: 603
    1)  I’m used to working in Hexagon, Carrara, CorelDraw where we have pretty large “viewpoint”/workspace & in comparison Daz Studio has a pretty small  “viewpoint”/workspace, is there a setting or a way I can adjust that into a larger work area?
    In my experience, the "floor" is not the whole of the workspace. it's more of a directional reference. I have many scenes and sets that dwarf the floor grid.
    In Iray, don't use a skydome, but set the sky in the render settings. I use TerraDome 3's skies, even when not using their ground. Also First Light Skydome is useful, but limited to early morning/late afternoon images. The use of a skydome in Iray actually blocks the light's rays.
    Keep in mind that Deviney's brushes are for photoshop, they're not D|S tools. There are some wake meshes available on ShareCG.
    Thank you,
  • MarshianMarshian Posts: 1,465
    Hi Turk_WLF-  Did you get Ocean Wide to work as expected?
    Thank you,
