Dson Importer files scale 0
I seem to be able to import a genesis figure into poser 2012 64 bit update 3 and yet the imported file is set at scale 0 and no matter how much I increase the model size it still seems not be display.
Are the bones all clumped at the origin, or are they in the right places? If they are clumped that does sound like scale, if they are in the right place it sounds more like the importer failing to find the DS geometry or failing to write an OBJ from it.
Not sure
Yep looking at the files written to disk it seems as though it is not creating an object just a cr2
Sorted it, I did not realise you also have to install the trx files.
