Young Face Morph G3F
in The Commons
Which product is this in?
thanks
thanks
What product is what in? I'm not seeing anything? Did you mean to post a pic or a link?
Click on the little gear icon on the morph slider and open properties. Highlight and copy the name (not label!). Go to your content folder in windows explorer (or whatever mac calls is) data/daz 3d/genesis 3/female/morphs and then paste the name into the seach box in the top right corver (don't know exacts on Mac). If the morph was saved correctly that should at the very least tell you who made it, and at best tell you the name of the product.
Hi Fisty,
tried that but can't locate it.
Its a red slider, I got it for G3M now I want for G3F.
It's under the 'Shaping Tab' under 'Head' if I remeber right.
'Young Face' morph for the G3F & G3M are in the Genesis 3 Female Head Morphs / Genesis 3 Male Head Morphs
it makes the faces a bit rounder, cheekbones slightly higher, and those sort of facial characteristics. It's not overwhelming to the existing face you have morphed from, it'll still be recognizable.
If it's the same "Face Young" morph that I have for G3M, it was part of Daz's Genesis 3 Male Head Morphs, and a G3F equivalent can be found in the Genesis 3 Female Head Morphs.
I think the Youth Face Morph is in Growing Up for Genesis 3 Male and Female
Are you sure? I can't check because I've a rernder running but they are groups into matting colors in the tabs depending on what product they are a part of.
There is a "Face Young" under "Head" in the Shaping tab that does make the face rounder. It's a medium reddish pink color. The Youth Morph is definitely part of Growing Up (bright pink).
Laurie
OK, I was talking about the Face Young but used the wrong label. Thanks for correcting me. I must have the other too, I'll try it out & see what it does.
