Genesis 3 Toon Generations 2 - Male Deformed (solved)
gbrittongbritton Posts: 46
When I try to move, change age, pose, etc. the G3TG2 male deforms and there is no way to recover.  Only happens on the male figure, female works fine. Does anyone have any ideas on how to fix this ?   Thank you.
Post edited by gbritton on
  • nonesuch00nonesuch00 Posts: 18,779
    It looks like you have 'autofit' the character to an object it's not to autofit to, but I'm just guessing.
  • Very strange.  It wasn't "autofit" like you said, but your response got me to thinking whether it could it be something else in the scene?  I have my default new scene load with a three point light rig which I rarely use and usually delete at some point while building out a scene.  I removed the rig from the scene and the G3TG2 male figure works perfectly now.  So i experiemented and found that only one of the lights in the three point rig is causing the problem - the kicker light.  Still not sure why, but that is my problem and removing it fixes my problem.   Still not sure why it only affects the G3TG2 male figure either.  So I'll mark this a solved for me, but still a bit of a mystery.  I will be removing the light rig from my default scene too.   Thanks for the response and help, Nonesuch00.   If someone else runs into this hopefully this post will help them as well.   Always good to have a community to ask for support.
