Young Face Morph G3F
Which product is this in?
thanks
  • 3Diva3Diva Posts: 11,974
    What product is what in? I'm not seeing anything? Did you mean to post a pic or a link?
  • FistyFisty Posts: 3,416
    Click on the little gear icon on the morph slider and open properties.  Highlight and copy the name (not label!).  Go to your content folder in windows explorer (or whatever mac calls is) data/daz 3d/genesis 3/female/morphs and then paste the name into the seach box in the top right corver (don't know exacts on Mac). If the morph was saved correctly that should at the very least tell you who made it, and at best tell you the name of the product.
  • PatroklosPatroklos Posts: 533
    Hi Fisty,
    tried that but can't locate it.
    Its a red slider, I got it for G3M now I want for G3F.
  • nonesuch00nonesuch00 Posts: 18,750
    It's under the 'Shaping Tab' under 'Head' if I remeber right.
    'Young Face' morph for the G3F & G3M are in the Genesis 3 Female Head Morphs / Genesis 3 Male Head Morphs
    it makes the faces a bit rounder, cheekbones slightly higher, and those sort of facial characteristics. It's not overwhelming to the existing face you have morphed from, it'll still be recognizable.
  • murgatroyd314murgatroyd314 Posts: 1,568
    edited January 2017
    If it's the same "Face Young" morph that I have for G3M, it was part of Daz's Genesis 3 Male Head Morphs, and a G3F equivalent can be found in the Genesis 3 Female Head Morphs.
    Post edited by murgatroyd314 on
    I think the Youth Face Morph is in Growing Up for Genesis 3 Male and Female
    Are you sure? I can't check because I've a rernder running but they are groups into matting colors in the tabs depending on what product they are a part of.
    There is a "Face Young" under "Head" in the Shaping tab that does make the face rounder. It's a medium reddish pink color. The Youth Morph is definitely part of Growing Up (bright pink).
    Laurie
    Laurie
    OK, I was talking about the Face Young but used the wrong label. Thanks for correcting me. I must have the other too, I'll try it out & see what it does.
