Blur in IRAY
Does anyone know if it's possible to apply motion blur to an animation (like when the dude in Matrix dodges the bullets and fights the bad guys)?
This product is on sale [1] and it's pretty cool, but appears to be limited to creating a single final frame, not an animation. I suppose I could just run it manually for every other frame in the animation and compile the slides into an mp4...but that's a lot of monitoring and clicking to get each individual blur frame to render.
I feel I'm overlooking something simple. Any thoughts?
Thanks!
[1] http://www.daz3d.com/motion-blur-for-iray
  • linvanchenelinvanchene Posts: 1,386
    edited January 2017
    I do not know what kind of Motion Blur other Iray versions support.
    What I do know is that the current DAZ Studio SDK offers only limited motion blur options for other render engines:
    Camera motion blur - the scene gets blurred if the camera moves - possible in DAZ Studio
    Object motion blur - Object movement is tracked relative to the hip bone-  in theory possible in DAZ Studio but useless for figures with morphs
    -> It seems what users may actually want is:
    Vertex motion blur - the motion blur from each vertex in the mesh is calculated.
    -> Not just the speed of the hip bone but the speed of each point on an object is tracked
    Matrix example:
    The bullets flying would only require object motion blur.
    A figure doging the bullets would require Vertex motion blur to also track the movment of arms and legs etc.
    In June 2016 a feature request for Vertex motion blur was added to the tracker. But that does not mean the request will be fullfilled.
    Request #219826
    -> If you currently want to create images with advanced motion blur effects you may need to use a 3rd party render engine like Octane and then export to the OR standalone version which is capable of rendering vertex motion blur.
    -> Even if Iray would support Vertex motion blur DAZ Studio would probably first need to be updated with at least a basic physics engine to properly calculate the speed of moving vertices.
    Post edited by linvanchene on
  • ToborTobor Posts: 2,300
    edited January 2017
    Iray internally supports camera motion blur, and has for some time using a programming interface. However, D|S does not yet expose that interface.
    http://www.migenius.com/doc/realityserver/latest/resources/general/iray/manual/concept/motion_blur.html
    Other products that use Iray demonstrate how the concept can be used:
    http://docs.autodesk.com/3DSMAX/16/ENU/3ds-Max-Help/index.html?url=files/GUID-25648CF2-A60F-450F-8880-8ADCD2EB13FF.htm,topicNumber=d30e531810
    For now, any motion blur effect will have to come from specially made props and textures (e.g. blurred propellers on an airplane), or some animated simulation, such as the product you mention.
    Post edited by Tobor on
  • TooncesToonces Posts: 919
    edited January 2017
    Thanks! My goal is to create a brief fight animation that uses the blur technique in my FAVORITE fight scene (at 3:19), where Mr. Smith pounds Neo into the wall:
    It just looks so cool. I guess that's 'vertex motion blur'? It's almost more of an after image to me instead of a blur.
    DraagonStorm achieves it quite well. I did a quick test on a simple pose (attached [edit: see the black background attachment, ignore the one with the white background]). I love how the product shows the after images and fades them appropriately. I just need to find a way to get it to do it for a full animation about 90 frames long.
    I also have photoshop, and found that I can create a gif from an image sequence and show after images at each frame by making the previous layer(s) visible (perhaps I can also make them fade too).
    I'm probably pushing daz animation too hard, lol, but it just gets so close to what I want! :)
    1132 x 741 - 363K
    645 x 608 - 195K
    Post edited by Toonces on
